Hi all,
I just did a DoD delete on my 2015 Chevy Silverado. It has a Gen V 5.3L.
I installed a stage 2 cam, new lifters, the DoD plugs and new valve seals and springs.
I also installed the Phase block in front on the Cam Phaser.
When I went to start it it ran really rough and gave me a P0016 code. Now it won't start at all.
When I took the timing chain off(without removing oil pan), I made sure the #1 cylinder was at T.O.C.
I know it was hard getting the chain back on, however, IF it was off, it was only a tooth.
Am I doing something wrong in HP Tuners?
I disabled the DoD system already.
I tried reloading my original file I made before anything.
It just won't run. It starts runs for 5 seconds and dies.
I also did the Crank sensor relearn.
Any ideas that might help?
I am hoping I can get it right with tuning instead of having to remove the timing cover again!
Any help would be so much appreciated.
Thank you,
Todd
