Results 1 to 3 of 3
Thread: e38 [ECM] 821 output
    Feb 2010
    College Station
    49
    For e38 ecu, in vcm editor there is an option to enable this output. Is there a correlation on what pin on ecu it actually goes to? Would like to use this output, but could not find much information on it.
    [ECM] 821 - 128K PPM Wheel Speed Output: If enabled, the PCM rear wheel speed 128k PPM output will be enabled.
    Jan 2014
    SoCal
    1,562
    On a Silverado that is X1 71 high, X1 72 is low.
    Feb 2010
    College Station
    49
    Quote Originally Posted by TheMechanic View Post
    Thank you. Looking in to it further, found some more confirmation that it is pin 71 as well. But very specific to engine and rpo code. For gas v6 shows as replicated tos signal, while for diesel shows as vss
