Do Not Write on trans, select as default?
Is it possible to have the transmission - do not write option set as a default? Sure would save some time when we're doing engine tuning and not touching the trans tables?
To save two clicks? Seriously?
over and over, yes. And especially if you forget to click it and write to the trans, the time wasted on doing that.
So how about you do a new read of the engine only and save that file. It can't ask you if you want to write the trans if it's not part of the file.
