Results 1 to 6 of 6
Thread: 2007 3v - idle source "lockout"
    Jul 2019
    10
    Been running into a few things with a 07 3v gt. One of the questions i have yet to have answered is what exactly is "lockout" in idle source? Im having some high idle/erratic idling that often happens when source is "lockout".
    Feb 2012
    TEXAS
    636
    Quote Originally Posted by Boost4Breakfast View Post
    so its an IDLE MODE FLAG. when your data log do you get lockout? there a couple flag modes, you want to be in (0) Dashpot normal driving. check you throttle body connections.
    -1 Dashpot Take foot off gas
    0 Dashpot Proposition Normal Driving
    1 RPM Control Mode RPM control mode
    2 RPM Lockout mode RPM outside dead band
    also all of these for modular
    Spark source values:
    0 Crank or underspeed
    1 Base
    2 Borderline
    3 Torque control
    4 Pre-ignition
    6 Stabilized low load
    7 Cold engine low load
    8 Idle feedback at minimum clip
    9 Idle feedback
    10 Spark set by on-demand self-test
    15 Output State Control
    16 Foreground Spark Borderline Clip
    18 Closed-Throttle Deceleration Spark
    Fuel Source
    0 -> Closed Loop fuel control mode is active.
    1 -> Cylinder cutout - Stabilized - Short Term Fuel Trim at lean stability limit.
    2 -> Some Exhaust Component too hot - Enrich Short Term Fuel Trim to cool exhaust temperatures.
    3 -> Cylinder cutout - Stabilized - Short Term Fuel Trim controlled by torque control feature.
    4 -> Cold engine/startup open loop logic - Cold start up engine table
    5 -> Stabilized normal driveability logic - Base fuel Table
    6 -> Lean fuel error logic.
    7 -> Engine running EGO monitoring testing - intrusive Short Term Fuel Trim control.
    8 -> Engine running On-Demand testing - Short Term Fuel Trim controlled by OBD-II exec.
    9 -> Cylinder cutout - Cold Engine - Short Term Fuel Trim controlled rich to avoid stumbles.
    10 -> Snap Adaptive - ramping Short Term Fuel Trim towards stoic for KAM update.
    12 -> Thermactor Air test - intrusive Short Term Fuel Trim control.
    13 -> Open Loop Development override - Short Term Fuel Trim set to calibrated scalar.
    TQ_SOURCE = Identifies the source of the torque reduction requestor;
    0 -> No Torque Reduction Requested (Torque Control Off)
    1 -> Torque truncation, transmission
    2 -> Traction Control
    3 -> Vehicle Speed Limiter
    4 -> Engine Speed Limiter
    5 -> Tip-in shock Control
    6 -> Tip-out Decel Control
    7 -> Torque Shift Modulation, transmission
    8 -> Engine Oil Temperature Control
    9 -> Fail Safe Cooling Control
    11 -> Turbo Charger
    12 -> Passive Anti Theft system (PATS)
    13 -> Tipin Torque Control
    TQ_SOURCE - Source of torque reduction:
    0 - Driver Demand
    1 - Transmission torque truncation
    2 - Traction Control
    3 - Vehicle Speed Limiting
    4 - Engine Speed Limiting
    5 - Tipin rate limiting
    6 - Tipout torque
    7 - Transmission Shift Modulation
    8 - Engine Oil Over temperature
    9 - Target N
    10 - Not Used
    11 - ETC FMEM - RPM Guard
    12 - PATS
    13 - OSCMOD
    14 - Speed Control
    Jul 2019
    10
    Yea, Idle Speed Control Mode = lockout at certain times while trying to idle. Sometimes itll stay like that and high idle for a few mins, other times itl settls into rpm control and idle correctly
    Jul 2019
    10
    Have also had it go into etc fmem-rpm guard once or twice - not sure whats causing that. Have ipc error check at 120k while figuring out what is causing the lockout
    Jul 2019
    10
    Oh, and some more info. It has a bbk 62mm (twin) tb and a roush cai. Has a set of lth's but other than that its stock
    Jul 2021
    10
    Same EXACT issue. Scrap the bbk TB. I put a stock one on and no more of that non-sense.
