Hello all, im needing to recode a set of injectors im about to replace on my 3.2L wildtrak and ive seen a few tutorials online about using forscan to do this, however i already have a hp tuner from previous years tuning a turbo falcon and was wondering if its worth buying the 4 credits to get into the pcm via hptuners instead, and unsure if this feature is definitely able to modify this way or would i be better off buying into the forscan option. Either way im spending money so if the hp tuner will trump the forscan tuner for the longrun ill chose that option but just dont want to lay out the 200 bucks now in credits if i can't code these injectors with it. Thanks in advance for any help
