Results 1 to 3 of 3
Thread: 18 Camaro lt-1 VVT Lockout
    Jul 2016
    14
    A friend of mine recently go an 18 Camaro with a cam installed. Texas speed stage 3. We had a problem with it showing a check engine light for P0011 (intake Camshaft Timing- Over-Advanced Bank 1) after looking at the tune file it looks like whoever tuned the car didn't tune out the VVT tables.
    I made the changes but I just want to make sure I did the correct things. This is my first time with the VVT stuff so I just want to make sure its right.
    Thank You for your time.
    alexnewlightfix.hpt
    May 2020
    43
    Just select none to camshaft under Airflow > Variable camshaft.
    Tuning Addict
    Jan 2015
    6,825
    Is it fixed/completely locked or "limited". You're better off with limiting - not sure why everyone wants to lock them unless it's just 100% necessary for clearance sake.
    If completely locked - then what Gustavo said. If not - tune in the cam.
    ~Greg Huggins~
