I have a 16 Ram 5.7 dropped off to me from a local dealership that is cammed (Comp MK201-303-17 kit). It appears this truck was dyno tuned in Missouri last year. My local dealership that it was traded in at says it idles too rough/drives poorly at low speed/dies sometimes when putting into gear. I have confirmed all of the above. It idles AWFUL (TPS bounces up and down like crazy), and it idles with negative TQ/negative timing.
I am fluent in GM platforms, and can make my way around a Dodge file starting from scratch, but am definitely not strong enough in the "what not to change, or you changed that wayyy too much" to identify a problem in the files very quickly.
I have attached the tune file it came to me with, and a short idle log. Any help, or direction pointed would be greatly appreciated!1 - White 16 RAM RCSB As Found.hpt16 Ram Rough Idle.hpl
