Results 1 to 7 of 7
Thread: 16 camaro issues after ecs supercharger install
    Aug 2020
    4
    just got done installing full lt4 fuel system,flex fuel kit, dsx iat/baro breakout harness, ecs novi 1500 supercharger, long tube headers, axle back and x pipe, and aem wideband.
    when giving any gas off idle the car will just stumble .
    im trying to get the car to be able to drive 30miles to the dyno tune location
    can anyone provide any help?
    or where to look to learn
    i tried to give it gas in the log
    thanks
    i had the car running with the lt4 fuel system(low side, hpfp, injectors, fuel line) before the supercharger install
    Aug 2009
    Calibrating
    3,376
    If I get a moment I’ll take a look
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2020
    4
    thank you i apprecate it.
    would it be any less safe to have it remote tuned instead of dyno tuned, and who would be the go to person around here or should i use someone like jannettey racing. everyone i checked with so far is booked out 1-3 months
    Aug 2009
    Calibrating
    3,376
    Tune all depends on who tunes it
    14 Gen 5 Viper
    Jan 2021
    23
    hello..poseo una configuracion similar... sin combustible flexible.. a8 con 11 libras a 6500 rpm .. si buscas mi historial he subido un mapa o 2 no recuerdo...y recuerda de no tensar tanto la polea del supercharger puede ocasionar KR.
    Jan 2021
    23
    hello...i have a similar configuration...without flex fuel...a8 with 11lbs at 6500rpm...if you're looking for my history i've uploaded a map or 2 i don't remember...and remember not to tighten the supercharger pulley so much you can cause KR.
    Jan 2021
    23
    the most correct...if you don't have knowledge...hire a remote tuning...if you don't have anyone nearby.
