Results 1 to 3 of 3
Thread: Writing to pcm problem
    Apr 2004
    Keller
    113
    I have been tunning my 2020 Jeep Trackhawk and writing to pcm and it normally takes around 40 sec.
    but today it took over 4 min. and I noticed it said write entire to pcm instead of Write calibration.
    Did I just cause a problem?
    what does Write Entire do different than Write Calibration?
    I hope I just didn't screw it up, and if so can I just write Calibration again.
    2020 Jeep Trackhawk, Functional Demon Ram Air Hood, AFE CAI, SW Headers, SW Cats, Solo Cat back Exhaust.
    Jan 2014
    SoCal
    1,561
    Yes. Writing entire takes significantly longer.
    Entire write does as it says, it will write all programming that is available to HPtuners instead of just the spots that have changed. Most of the time you don't need to do a write entire. On GM when you first program the elimination of VATs (anti theft) you need to do a write entire. Other software changes like SD often will require write entire.
    Remember HPtuners modifies only some of the software. You still in most cases will need the base factory programming on the ECM/PCM/TCM to be accomplished before HPtuners can do modifications.
    Apr 2004
    Keller
    113
    Quote Originally Posted by TheMechanic View Post
    Thank you for the quick reply, I guess for some reason it defaulted to write entire that time.
