2019 Mustang Whipple 3.8 P2119
I'm working on a 2019 Mustang GT with the Whipple 3.8.
When attempting to go WOT, the throttle pulls back, and I get a P2119 code. I've tried the TB model from a Whipple OS and got the same result, it just takes a split second longer. Any ideas would be appreciated.
If you roll into the throttle slow does it still do it?
Yes, and I did try to lower the throttle rate limit. I've found a "workaround" and would like to update this for closure. I was using the throttle body data from a Whipple OS configuration,and I'm using the stock OS. I went back to the stock throttle body model and the problem is solved. I have run into a new issue which I'll start another thread for which isn't TB related.
Thank you for the reply.
