Anyone ever had this code a not had an issue wit the pedal or the throttle body? I have tried new ones of both and still sets that code at about 75-80% throttle. I've checked the wiring and it hasn't been pinched or melted anywhere. ECM issue?
Is it low on toner? (HP Laserjet P2035)
hahaha sorry fat fingered the code number. 2135
What are you working on?
Are the APP & TB & TAC matched to the original application for the PCM & OS?
Swap vehicle?
Stock harness or modified stock harness or aftermarket harness?
Have you verified the pinouts at all the components at both ends?
Have you verified the wiring/pinout info you're using is correct?
408/ stroked 6.0 stock heads, connect and cruise harness and computer. haven't got into checking pin outs yet. Was just wondering if anyone had seen anything like that. I have extra known good pedal, throttle body, and ecm. same issue. im guessing its got to be a wiring problem.
Can we start with a year, since that's the very first thing I have to enter when looking up service info? And then the make? And platform? Or is it a secret? Proprietary? Can't post the files?
It's a GM connect and cruise kit, I couldn't tell you if the designate them by year. thanks for your help I found the problem.
