Results 1 to 9 of 9
Thread: P2135 code
    Nov 2019
    Idaho
    12
    P2135 code
    Anyone ever had this code a not had an issue wit the pedal or the throttle body? I have tried new ones of both and still sets that code at about 75-80% throttle. I've checked the wiring and it hasn't been pinched or melted anywhere. ECM issue?
    7,647
    Is it low on toner? (HP Laserjet P2035)
    Nov 2019
    Idaho
    12
    hahaha sorry fat fingered the code number. 2135
    Hot Rod Specialties
    HotRodSpecialties.net
    71 Chevy C10 w/408ATK
    7,647
    What are you working on?
    Are the APP & TB & TAC matched to the original application for the PCM & OS?
    Swap vehicle?
    Stock harness or modified stock harness or aftermarket harness?
    Have you verified the pinouts at all the components at both ends?
    Have you verified the wiring/pinout info you're using is correct?
    Nov 2019
    Idaho
    12
    Swap vehicle?
    408/ stroked 6.0 stock heads, connect and cruise harness and computer. haven't got into checking pin outs yet. Was just wondering if anyone had seen anything like that. I have extra known good pedal, throttle body, and ecm. same issue. im guessing its got to be a wiring problem.
    Hot Rod Specialties
    7,647
    Can we start with a year, since that's the very first thing I have to enter when looking up service info? And then the make? And platform? Or is it a secret? Proprietary? Can't post the files?
    Nov 2019
    Idaho
    12
    It's a GM connect and cruise kit, I couldn't tell you if the designate them by year. thanks for your help I found the problem.
    Hot Rod Specialties
    Nov 2017
    1,466
    Quote Originally Posted by Hot Rod Specialties View Post
    And no feedback on what the problem was?
    Nov 2019
    Idaho
    12
    Sorry, I had a power issue to the trans computer. I never though it would've caused it.
    Hot Rod Specialties
