I have a log that i made a couple days ago for someone who has been helping me diagnose an issue because unfortunately i do not know enough about tuning and all this stuff to really understand it to the level that it needs to be understood. Long story short, i'll post his response as well as the the log, and for anyone who is interested, the tune as well.
His response:
Hi, the tune is way too rich and the fuel system is still running out because of it. Afr is commanding .81 but its hitting .72. which is stupid rich. Fuel rail pressure needs to stay at 2900psi not drop to 2000psi. Injector pulse widths need to be under 6.0ms on Direct Injection motors. If they go above that then fuel is spraying outside the injection window. That means unburnt fuel is going out the exhaust and you are actually running lean even though it shows rich which is why you are getting knock retard with only 6 degrees of timing. The tune is a ticking time bomb.
So basically it needs leaned out so the high side fuel pump can keep up and to lower injector pulsewidths so fuel is injected on time which will actually richen it up since the fuel will be ignited on time and wasted out the exhaust. Then it will take a lot more timing without KR".
What exactly needs to be done? I am really trying to get a grasp on all of this. What needs to change exactly, as far as parameters, etc. And what changes need to happen? 2 test hits headed home.hpl2019 Camaro SS Fireball 2.hpt
