4.8, e67, Summit 8720r1, valve springs, all stock otherwise.
The truck drives great with the exception that it will, at idle, move into Open Loop and command 1.14 Lambda, stays at that for 8 seconds, then switches to .85 lambda. It will hold that 5 seconds, then revert back to 1.0, my target idle.
I didn't notice the initial 1.14 command, but I did notice when it switches to .85 because the truck will start to hunt a bit. No check engine lights throughout the entire 45 minute log, no drivability issues.. just this weird thing.
Could it be something like a purge event for the EVAP? Cat test? When I saw the .85 I assumed that was my Catalysts Over Temperature kicking in because that would make sense.. I guess? It's been really hot here, so I'm just trying to connect whatever dots I can. Snippet of the log and the tune are attached.
EOIT Adj_43_weird idle dips.hpl
48 97x_Big Changes_Lowered AC Air.hpt
