DELPHI Injectors
Anybody recognizes this injector? I know they been used stock in GM cars. Need some basic injector offset data.
Got a set of those and it seems they are 60lb @ 3 bar. Stock tune would do.
Thx
You need to know the part number before you can find the application that used it, there are several that use that body style so a picture isn't enough to identify which ones they are.
Unfortunately I have no other info besides 60lb. No part number on it. I was able to work on slopes but still need to figure out dead times.
That "several" might do the job - any idea on where they might been used stock?
Is that photo from ebay? I think so. There is no data for those injectors because they have been hacked on, by a hack.
The largest injector of that style GM ever used in anything was 12613412, in the L96, which was only 50.4lb, and that's at 58PSI.
Yeah, it is. Grabbed a set cheap, last time tho...they shipped from Cyprus LOL They work fine, the issue is hot start after while.
Extended cranking - which means dead times are not OK...most of the time.
Thank you!
