Results 1 to 3 of 3
Thread: gear/tire size change
    Aug 2022
    1
    I have a 1999 Chevy Suburban I lifted and put 33" tires
    hooked hp tuner went to edit and gear/tire wizard, when I look at what is already programmed in its not a tire size 0.70 with 3.42 gear
    I input my tire size 33.1 and the rear gear 3.42 and hit adjust and it now shows tire size is 1.08 with gear 3.42
    I see videos with people doing the same thing and the tire size is correct on theirs. is it because 99 model or am i doing something wrong?
    Thanks in advance
    are the units of measure correct? also a better option is using the bluecat trans tool, by far the best way to feel a HUGE difference
    Jan 2014
    SoCal
    1,575
    Are you sure you are not reading the multiplier? As to bluecat it is great but you still have to do the tire wizard first. Post your tune.
