it is currently set at 2 bar and i used a harness that repins it at the trans, the front speed sensor plugs into this harness and the rear speed sensor is plugged into my transfer case
if i did it right this is my tune the last guy did, its an 07 suburban 4x4 5.3 lc9 stock bottom end, tsp stage 3 truck cam 216/220 .353/.353 .600/.600 112 110, high flow oil pump with shimmed spring, 2.3 twin screw whipple supercharger with a 3.85 pully i believe 10 gallon ice tank dual pass and single pass heat exchanger with two pumps, longh tube headers 1 7/8 tubing tp 3" collector 3" catless y pipe 3" corsa cat back sport system, stock throttle body, upgraded rocker bearings and pushrods, 50lb injectors stock fuel pump, 4l80e stage 2 build 2400-2600 stall, yukon limited slip with 3:73
