Thread: AFR State
    Feb 2019
    Indiana
    135
    AFR State
    Tuning 04 cummins.. Ran into a AFR state master fuel correction.. Not sure where to look to get this sorted out
    22-08-09 19-30-25.hpl
    jacob cummins rev6.hpt
    is this a stock truck / no mods?
    not much fuel in that file for the timing going at itAttachment 123150
    this should fix the limit, but looking at the log and file seems to be getting the fuel but there is not total fuel rate/uncompensated fuel rate mm3 to know where mm3 is at
    I added some pulse to the fuel, and pilot timing as well. you'll need to spend some time in the timing map and I run the fuel psi to 180 mpa 130mm3 from 2000rpm up
    Jim might chine in on that correction reason but does not seem to be an issue that little amount of fuel unless you have bigger injectors in there, hope that helps
    2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
    2008 F-350 03 5.9
    Fumminstuning.com
    Feb 2019
    Indiana
    135
    Quote Originally Posted by guy-ffc View Post
    Thanks for the help.. I should have said its got s&s 200% overs and dual stock cp3s
    oh ok i wondered haha
    2008 F-350 03 5.9
    Fumminstuning.com
