Tuning 04 cummins.. Ran into a AFR state master fuel correction.. Not sure where to look to get this sorted out
22-08-09 19-30-25.hpl
jacob cummins rev6.hpt
is this a stock truck / no mods?
not much fuel in that file for the timing going at itAttachment 123150
this should fix the limit, but looking at the log and file seems to be getting the fuel but there is not total fuel rate/uncompensated fuel rate mm3 to know where mm3 is at
I added some pulse to the fuel, and pilot timing as well. you'll need to spend some time in the timing map and I run the fuel psi to 180 mpa 130mm3 from 2000rpm up
Jim might chine in on that correction reason but does not seem to be an issue that little amount of fuel unless you have bigger injectors in there, hope that helps
2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
2008 F-350 03 5.9
Fumminstuning.com
oh ok i wondered haha
2008 F-350 03 5.9
Fumminstuning.com
