Results 1 to 2 of 2
Thread: Part throttle timing is at 0 degrees!
    Dec 2015
    Reno
    63
    Hello,
    So with the car idling, the timing is where it should be. Once I start driving (part throttle) spark goes down to zero and once I let off the throttle at speed the timing goes back to where is should on the timing table. Any help will be awesome been chasing this issue for 3 years now...
    13,559
    I would like to know why you set the entire low octane timing table to zero degrees. That is a completely wrong thing to do.
    Copy the high octane into the low octane table and then remove like 4 degrees from the entire low octane table.
    Then zero out all the negative numbers in the ECT spark correction table, it's removing a ton of timing while the engine is cooler and exactly in spots where it would be accelerating from a stop.
