0804am VE takes a dive.JPG0804am lean pe SD w MAF.hplSD Tune Final SD w MAF w ltfts no fuel cutoffs.hpt0803pm sd only.hpl
2006 GTO 403ci. Car background was SD tune only with no MAF physically present prior to me owning the car. Few years back I installed a card style maf for NY compliance for NYS inspection, though typically always run it in SD only. Now...decided might's well tune the MAF in and use it. I was always reluctant since its an over the radiator intake, short run so MAF always looked erratic in various points of the curve but...anyway.
Problem: VE takes a dive forcing PE lean until ~3600 when maf takes over, and VE magically comes back to reality. Picture included.
Running SD only there is no issue.
Running MAF only there is no issue.
Turn the Maf back on and this problem presents. I moved MAF enable down, the problem moves with it. But this i believe is just masking the problem allowing maf to come into play. As of right now moved my MAF enable to 2200 and all seems well and goes into PE fine. But....does not solve the riddle. I'm stumped.
Anyone have any thoughts? I would figure someone has seen this. Had HPT take a look and they state the program is doing as it should. Almost like some sort of VE correction factor since, it commands PE right away but SD goes out to lunch. Thanks to all in advance!
