Originally Posted by
blindsquirrel
When you highlight, you have to select only the cells. You can't click the rows/columns to highlight like you do in HPT because in the spreadsheet the labels get copied the same as the data cells, then when you go to paste it says 'no way, that's too many things you can't do that'.
Open the Short Pulse Adder table in your file. Highlight everything and select 'Copy with Axis' then paste that into a text editor. You'll see that the true column labels match what's in the spreadsheet which is un-rounded numbers with 3 decimal places, while the regular table in the editor shows them rounded to one decimal (3.875 turns into 3.9, etc.). So it is the same.
