hi, i have installed a 2007 6.2 l from a cadillac escallade 6.2l into my 53 ford f100, i`m a newbee so i`m learning a lot by looking on this forum,attached are the specs of the engine i built, my tune file, as well as a file from a scan i did yesterday when trying to start it. the tune, i deleted vats, vvt, dod, swapped over the injector data from a 2010 camaro (i have ls3 injectors), swapped over the transmission data from a 09 cadillac ctvs, with a noid light i have no pulse, confirmed with a volt meter that i have power when cranking over the engine, nothing on the ground side, i have checked and i have engine rpm, map sensor was checked, when scanning yesterday and looking over the data i noticed no pulse to injectors as well as nothing from my mass air, no active error codes present. i have a fuel guage set up and have 58 psi at the rail, im sure i screwed something up with the tune, i would really appreciate your opinions
