Results 1 to 15 of 15
Thread: VCM Scanner (Beta) now has actual histograms
    Sep 2002
    Chicago, IL
    6,394
    What we've called Histograms in versions 2.24 and older were not actually histograms.
    VCM Scanner now has actual histograms.
    They can be found in the Graph display.
    Go to your "Graphs Layout", click the drop down icon for "Add Graph", and you can now add a histogram.
    A RPM histogram is now also included in all the default layouts.
    We got this guy Not Sure, ...
    Nov 2006
    2,608
    Awesome..
    hey heads up.. the latest beta seems to have a bug on the graph display. +, -, AVG, etc is cut off.
    Tuner at PCMofnc.com
    Sep 2002
    Chicago, IL
    6,394
    I think that's a DPI issue. Does the current release version have that same issue?
    actually, it's because you have a long named Graph.. and it's expanding that list wider.. I'll see if we can come up with a more elegant solution.
    Nov 2006
    2,608
    OK understood but I've used this layout withthe same graph names since at least 5/2021. I name/date my layouts
    Sep 2002
    Chicago, IL
    6,394
    Yup, we've identified the problem and it will be resolved in the next beta.
    Thanks!
    Nov 2006
    2,608
    Thank you Keith! Really appreciate everything!
    Jul 2020
    VIC Australia
    1,107
    Handy. Spends most of her time at -3 to -2% on the pull.
    Nov 2006
    2,608
    Thanks!
    Keith, have you ever considered adding MODE to our graphs.
    I always use the example if someone builds a 20 million dollar house in a 100K neighborhood that doesn't mean it's now a 1 million dollar house neighborhood.
    Sep 2002
    Chicago, IL
    6,394
    I don't think adding mode would be too terribly difficult.
    Can you give me an example of how you might configure it, and a common use case?
    Nov 2006
    2,608
    Thanks for the consideration..
    I think it would have to also include some rounding down of the units... So the results would show say -5% instead of -5.3285%.... or even -5% instead of -6% or -4%.
    Else using mode would return numbers too limited in scope.
    I do this in excel for old chip car tuning. (yes I still do this.. lol)
    I'll use a formula to round down the numbers like this. - note this is not just taking decimals off but rounding by 2, 5, 10, whatever.
    =ROUND(X/Y,0)*Y
    Where X is the unit to be rounded and Y is by what.. 5's, 10's, 1's whatever.
    with Y = 5 above that would return
    7 = 5
    2.5= 5
    3 = 5
    9 = 10
    2 = 0
    But I think Mode would be helpful for any graph plotting fuel trim error or Eq error. It would be helpful to know say a car is most often 5% rich in a area as opposed to an average number that includes a super high or super low outlier.
    If a cell has (10) +5% hits and (1) -20% hit the cell would report +5% instead of 2.5%...
    Jul 2020
    VIC Australia
    1,107
    2 more suggestions to add to the scanner if possible is can we please have conditional filtering and ability to include flags in our filtering
    Conditional Filtering
    E.g. MAF tuning requires two graphs, 1 closed loop and 1 open loop. Each graph has it's own filters
    With the advanced filter I could have just 1 graph.
    Code:
    If (closed_loop == true && my_closed_loop_filter_conditions == true)
       Populate_Data();
    Else If (open_loop == true && my_open_loop_filter_conditions == true)
       Populate_Data();
    Flags
    E.g. Fuel trim cell = 6 and throttle control source = Pedal or cruise
    6310 = 6 AND (12133 = "Pedal" OR 12133 = "Cruise")
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    I really often get the issue, the chart show different value than the channels. does anyone know, what can be the reason?
    Sep 2002
    Chicago, IL
    6,394
    Quote Originally Posted by Auto-Hentzschel View Post
    The channels display shows your nearest data point. It does not interpolate.
    The chart display draws lines between data points, and if you hover anywhere over that line, it shows you the interpolated data between the two data points.
    Sep 2015
    Schleid, Germany
    341
    faster polling interval does not solve it? any solution to fix that?
    Jul 2020
    VIC Australia
    1,107
    Ditch the SAE channels
