Results 1 to 2 of 2
Thread: Mph > km
    Aug 2022
    1
    Mph > km
    Where can I choose a template that indicates the kilometers driven in KM and not in MPH (miles per hour)
    Or... where can I adjust that?
    Apr 2018
    296
    The actual data itself is controlled by the data file. If the values there are in kph, then that's what the needle on the gauge or text will show. If that data is in mph, then you can convert that by clicking on the config of the data Input File (top right), then at the bottom in the calculated fields, choose your speed field, and choose Mile -> Km. This should also work for just distance fields.
    Alternatively, there should be several calculated fields (which are surrounded by parentheses) which can be chosen such as "(Distance km)" which might be more what you're looking for.
    If you're talking about the actual label on the gauges themselves, there is a Label textbox on the Display Object Properties that can be changed from "%su%" to whatever you want like "KPH".
