Results 1 to 19 of 19
Thread: 2000 silverado RCSB 4.8 rich idle
    Aug 2022
    11
    I have a 2000 RCSB 4.8, sloppy stage 2 cam, 78/75 turbo, intercooled, 2bar map, siemens deka 80lb injectors, SD tuning, 4l80e with 3200 stall.
    Its been a great father/son build with the kids. I'm very new at hptuners and in the learning stages. You guys have a lot of knowledge and i wanted to see if you could give me some ideas on what to look at. We got everything completed and loaded a base tune. Fired it up and its idling super rich. I found the siemens deka 80lb injector info online but i seen all kinds of different info on it. I load my file and see what you guys think. Any help will be greatly appreciated.TURBOTRUCKREV2.hpt
    Aug 2022
    11
    idle log
    22-08-14 21-43-53.hpl
    afr at idle was about 11:1
    Dec 2018
    Washington State
    182
    Take some fuel out of your secondary VE table
    Aug 2022
    11
    i do not see a secondary VE table, is located next to the main ve under airflow?
    Also look at how my timing is jumping anywhere from 0-35 very erratically.
    7,648
    Custom OS does away with the primary/secondary VE thing.
    Aug 2022
    11
    yea it does have a custom OS for SD, flex fuel, and 4l80.
    Just struggling with the super rich idle and erratic timing also
    Aug 2009
    Calibrating
    3,373
    Min fuel is a lot of the problem I bet
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2022
    11
    Min fuel milligrams under transient? I lowered it from .029 to .019 with not much change. What do you recommend?
    Mar 2011
    Ripley, MS
    1,865
    You've got a few issues with the tune that are causing your "rich at idle" symptom.
    The primary reason is the MAP sensor calibration. You had mentioned that it's a 2000 model Silverado 4.8L with 2 bar MAP sensor.
    The tune is for a 2002 model Silverado with a 408 Stroker and a 3 bar MAP sensor.
    That MAP sensor calibration has it idling around 94-96 kPa at 950 rpm. It typically would be in the mid 60 kPa range with a 4.8L and that cam idling at 950 rpm.
    What is the part number of the MAP sensor that you're using?
    Aug 2022
    11
    my map sensor part #is gm 12615136
    Mar 2011
    Ripley, MS
    1,865
    Here is the tune with the proper MAP sensor calibration, engine displacement and a good base VE table.
    TURBOTRUCKREVKW1.hpt
    Aug 2022
    11
    thanks i appreciate it!
    I will give it a try tom.
    Aug 2022
    11
    thanks kevin that definately cleared things up for me i appreciate it.
    its idling now about 15.8-17.2 afr.
    Timing is still jumping up and down quite a bit but i dont know if thats normal or not.
    i will post the log and tell me what you think needs adjusted.22-08-18 21-33-37.hpl
    thanks again!!
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by 71touring View Post
    thanks again!!
    That looks much better! Now the MAP sensor is in the mid to upper 60's at idle as it should be.
    It's pretty typical for the timing to move around at idle as the Timing Trim tables are active.
    Now it can be properly tuned.
    Feel free to hit me up if you don't already have a tuner. I'll get it dialed in for you.
    Aug 2022
    11
    I do not have a tuner yet, I have a Wideband gauge but it?s not linked to hptuners yet. I?m sure your gonna need me to get that hooked up before we can dial in the tune correct?
    Mar 2011
    Ripley, MS
    1,865
    I will need the wideband in order to tune WOT properly. However, it isn't required for part throttle tuning.
    Aug 2022
    11
    Ok I am definately interested in you getting my tune dialed in. Let me know what you all need.
    Thanks!
    Mar 2011
    Ripley, MS
    1,865
    Thanks!
    Send me an email at [email protected]
    Aug 2022
    11
    Sent
