Results 1 to 8 of 8
Thread: Question on scanner when logging gen v vehicles and oxygen sensors PLEASE READ TUNERS
    Advanced Tuner lt1z350's Avatar
    Mar 2014
    Dandridge, TN
    560
    So been seeing all gen v vehicles have a very lazy bank 2 once headers are installed and got to digging on a buddies car as wot the narrow are not even close to same like 50mv off each other. So looked for leaks any sign of a problem. We found some exhast leaks on KOOKS headers at those sorry pressed in bungs. He put a vacuum reversed blowing into the pipe and sprayed soap and sure enough one bung was leaking gen 6 camaro for those that now wonder if your car or a car you tune has some problem.
    But the sensor is always lazy idle which I figured was from not enough heat too far down so on. Typical header issue but the bank 1 is not so bad. Im tuning his car and yet he finds this issue on MY channel list. Bank 1 sensor is poling at 0ms and bank 2 is poling at 200ms this is a default scanner setting. I have had the list for a long time and just kept adding to it so probably setup in a very old beta around 2017. So now I use my latest beta that sucks as missing tables for removing emissions controls(another thread topic) and I look at the settings available to me and there is no longer a 0ms and if I delete and re add them its now at 200ms on bother sensors so at least equal. I feel stupid for not seeing this but not something I thought I needed to check. He did a log on it with both at 0ms some older list from a buddy and low and behold its reading the same left to right at idle. This is a major screw up from hptuners on scanner settings. Maybe I should have caught that I just never thought to look at settings like this.
    But now I see it and wanted to share Im sure someone is going to say I knew this you should have checked but for the rest of us on a very old list you may want to check it out.
    Next whats the best setting? Slower or faster? is this the time it takes to process before it gives a value so longer maybe more accurate? that is really my main quesion on whats best. I have used narrow band settings to find anything from blower leaks to header gasket or sensor leak on many cars. While a narrow is not a wide its a good judgement point as the sensors today are not the narrow of yesteday with no heater we couldnt trust at all. I like to compare more left to right vrs giving me a value just more for balance of the engine. I have found 75whp on a car on the dyno that had a blower leak so find this as a valuable tool when its working as it should anyway.
    So hoping for some of you guys like myself that have been around a little while to chime in on it please as I know most of you will read this.
    First 9 second 6th gen lt4 zl1 stock blower SHC SBE boost only.
    2013 cadillac ats 2.0t Big turbo-gone
    2007 tahoe 5.3 lsa blower on 14 lbs boost 6l80e swap 2009 os
    2017 zl1 a10 big gulp/2 inch headers/ 9.55 lower/ e85/bigger hx /103mm tb / Synergy trunk tank and underhood kit/methanol injection with torqbyte controller and prometh pump / Jokerz performance R&D ported stock blower/ lme cnc heads /GP tuning custom cam. So far 9.30@150
    May 2003
    South FL
    1,378
    I'll have to check my settings. I often see bank two behaving the same way. Usually the trims show bank 2 wants more fuel. I still use the narrowbands to ensure that LTFT's don't drift too far or go positive and add fuel at WOT.
    [email protected]
    Owner/GM Calibrator
    Sep 2021
    Lexington KY
    199
    Quote Originally Posted by lt1z350 View Post
    Wow. I have actually replaced my Bank 2 for this reason. and kept thinking I had an exhaust leak, etc. Ill take a look at mine and see
    Dec 2018
    36
    The timing of this thread is epic. I actually just noticed this exact thing about a day before you posted.
    I did some checking and my B1S1 is set to 0ms but it's not an option in the dropdown if I were to change it... only goes to 10ms. As for B2S1, it was set to 100ms and I only have the option to go to 10ms not 0.
    I've gone back to 3.7 VCM scanner and 0ms isn't in the dropdown there either.
    Mar 2014
    Dandridge, TN
    560
    Quote Originally Posted by WingsAA View Post
    Yea so I put two more cars I tune on my new list and they run side by side now at 10ms. I cannot believe this problem has been a scanner setting all along. I can?t even tell you how many have replaced sensors including my own due to this problem.
    Now I need to find better narrow band settings to wake them up some at idle. Playing with 19 zr1 settings so far and they look to run a little faster and not stick rich so often.
    I have always blamed this on heat and was going to wrap the collectors as a test as I don?t drive in the rain anyway with my zl1.
    Seems if build a new list using newer scanner it?s now choosing 200ms as default on both. But how many of us are on older made lists? I bet a lot.
    Mar 2014
    Dandridge, TN
    560
    Yea please report back looking to see how many this has bitten and if changing it helps as I have seen so far.
    2,808
    Good catch
    Tuner at PCMofnc.com
    Dec 2018
    36
    I was thinking my bank 2 sensor was going bad as well. Had been looking up the specs to test it. They are working fine with with the polling interval updated to match.
