I have two unique situations I'm hoping I can tune and make adjustments to the behavior on my 2018 Silverado. I'm looking for feedback from others before I buy more credits. My truck has the 5.3 Flex Fuel V8 and the 6l80 transmission.
The strange behavior I've noticed is when I'm "off-road" (forest service roads) and I'm trying to maintain any speed between a crawl and 15 MPH going downhill.
Behavior 1) I've noticed when the truck is high range on the transfer case and manually set to first gear it will free wheel until it gets to about 15mph, then the transmission will "catch" and start engine braking. The truck does a fairly good job at holding 15mph as it will alternate between braking and freewheeling with the engine/trans. Is there any way to lower this threshold, or eliminate the free wheeling completely? On some FS roads that make up mountain passes, 15mph is too fast. I believe this is a transmission parameter.
Behavior 2) In 4lo range I can only get engine braking at a crawl (2 MPH). It will only work when I am in 4lo, locked into first gear, and pointing down hill. The engine/trans will be engaged immediately and hold the truck at a low speed. If touch the gas pedal it will immediately start rolling ahead and the engine RPM will rise (I've let it get to 4k rpm with zero engine braking before I get the brakes). This tells me the engine and transmission are coupled, but the ECM is holding the throttle open; which is different than in high range. Is there any way to change these parameters so I can maintain engine braking?
This is very frustrating, because every other older GM vehicle I've driven allows me to put the truck in 4lo, pick a gear that gives me appropriate engine braking, and then apply throttle to set my speed. As the truck sits, I'm forced to use my brakes more than I'd like doing down these National Forest mountain passes if need a speed between a crawl and 15 mph. Hill decent control also doesn't like working for long periods of time and it is also the brakes.
