I forgot I had this, but this is the actual truck that provided the stock L96 file I use for doing all the 12613412 data conversions. Heh. I had the tune file from the repository for a long time before I somehow happened across this pic somewhere totally unrelated.
Im gonna go ahead and pull the trigger on those injectors. Are there any wiring adapters that are better than others to go from multec to ev6? If you have the conversion data handy for those to the p01 ecm i would gladly take it.
Replace the pigtails, it's way too easy to get crappy quality with the plug-in adapters.
https://www.ebay.com/itm/132370243894
Im 58psi with mechanical gauge, running corvette regulator with built in return, so im returnless to the rail.
I found a couple threads just checking to make sure i change the correct things. Found one tune you posted for it and noticed the prime for starting you had most of them 0 instead of the stock values. Wasn't sure if i should make changes to those also.
Ok thats helpful. Just change those 3. There were other sections there that were different. wasn't sure if i was suppose to change those also.
So in theory these settings should be right for the 50lb injectors. I saw someone else posted different kpa settings going from 49-54 instead of 50-55. Not sure if thats really matters that much?
50# injector setting 1.hpt
There were a bunch of people conflating these injectors with the similar but different 12609749s.
Ya i saw that. i was trying to compare my injector data with some of the other tunes i have seen on here that said they were right and all of them have different values in different spots. so not sure which one is really right. Have to search some more. Looks like most people have the limits for min and default pulse of .243, and all have different kpa values with small changes.
Conversions done using the spreadsheet give data that looks OK but really isn't, not if the source is a late E38/E67, like these are. And even two different people doing their own manual conversion could come up with very slightly different numbers here and there. Sometimes it's just differences in the number of digits used and the rounding that then happens.
I show most of how I do it here: https://forum.hptuners.com/showthread.php?98228
