hey guys looking for some help here ive got a turbo c10 im trying to get sorted out and now that its ready to start boost tuning im having trouble with the intake manifold absolute pressure channel stopping at 105kpa. im also recording the map voltage and the map 2 bar psi channels which read as they should. also the graph at the bottom records the proper kpa but none of the histograms are recording above 105kpa even when it gets into those cells. ive tried removing the channel and connecting to the vehicle before re-adding it with no luck. the tune has the 2 bar patch applied and the maf failed to tune speed density but it had the same issues with the maf functioning as well dave c10 rev6 try 3.hplDaves Truck Revision#6_SD.hpt
