Results 1 to 3 of 3
Thread: What causes P1381 DTC?
    Nov 2014
    Utah
    60
    P1381: Misfire detected-no communication with brake module.
    Started getting a hesitation at light cruise~1800rpms. Checked the DTC's . This code P1381: misfire detected-no communication with brake module and P0300: random misfire detected showed up. What does the brake module have to do with a misfire? This is a LS swap car. There is no brake module.
    p0300
    Jun 2016
    Tuscaloosa, Alabama
    71
    Need more info. What ecm and motor do you have? I think p1381 is for the variable cam timing module
    7,715
    What causes it is not having the ABS parts while leaving the DTCs for ABS comms enabled.
    Why P1381 exists is because the ABS can determine (or make a guess) by the pattern from wheel speed sensors when it might be in 'rough road conditions', and it lets the PCM know to ignore anything misfire-related when that's happening, because the PCM can't on its own tell the difference in crankshaft speed variations caused by rough road conditions or caused by an actual misfire.
