Results 1 to 8 of 8
Thread: is there anyone who can fix this tune? i will pay $$$$
    Aug 2009
    Calibrating
    3,376
    What’s the specs of everything??
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2021
    9
    6.0 block ored .070 over 6.2 pistons elgin .575int. .575exh. lobe sep. 108 int. 116 exh. dur .050 220int. 224exh.
    RHS LS3 heads 280cc runners 70 cc 2.165 int. 1.60 exh. valves comp cams 1.8 pro magnum roller rockers deep motor fab. manifold 102mm torquerush tb 03 silverado 2500hd, 60# Bosch injectors, 91 octane, naturally aspirated
    Coil Resistance: 12 Ohms / High Impedance
    Static Flow Rate: 60lb/hr = 630 cc/min @ 43.5PSI ( 300kPa )
    Gain: 0.12ms/MG
    Offset: 0.055ms
    Turn on time @ 14VDC: 1.14ms
    Turn off time: 0.85ms @ 300KPa
    Amperage: 1.0 Amps
    Pressure: Min 30PSIG/ Max 100PSIG
    Variance:2 %
    405
    2,336
    Quote Originally Posted by Stevess7 View Post
    Gain: 0.12ms/MG
    Offset: 0.055ms
    Amperage: 1.0 Amps
    Variance:2 %
    I would bet those are lobe center lines not LSA. And that should be easy to tune regardless of the LSA. What is the problem or do people have to keep playing 20 questions with you trying to pry information out of you.
    Pro tip, when asking for help you should give as many details as you can including vehicle type, is it a swap, etc. I won't even waste my time trying to look at files without knowing everything.
    7,710
    Pay attention in school, kids. You'll need it later.
    Mar 2021
    9
    its really lopey when warm idle and driving it falls on its face at 3000 rpms and above, idles crazy and slow to idle down
    405
    2,336
    Well I'm done. Bye.
    Jun 2016
    Tuscaloosa, Alabama
    71
    Your control voltage on the ecm is showing 24volts. do you have more than one battery in the vehicle? I was wondering why the load was so high and throttle pedal not acting reading correctly.
