Results 1 to 12 of 12
Thread: 8L90 to 10L80 Swap
    Aug 2022
    4
    8L90 to 10L80 Swap
    I have a 2015 GMC Yukon Denali 4WD with the 8L90 tranny. I'm swapping in a 10L80 and would like to know whether or not my current TCM will support it or if I will need to get a different TCM. This is being matched up to a built LT-1 from a C7 w/ LT-2 Intake. Any input is greatly appreciated.
    13,565
    I see no way of it working but stranger things have happened.
    Aug 2022
    4
    The truck currently has a T87 TCM. The newer models (2017 and up) with the 10L80 have the T87a TCM. Seems simple, as the only difference in the tranny's are 2 additional gears for the 10 speed. Both trannys have the same case, size, etc. Seems like it should work.
    Aug 2009
    Calibrating
    3,373
    T87a can run a 10 speed, that’s how we get around the t93 trans controller on the 10 speed tuning
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2022
    4
    Quote Originally Posted by Ben Charles View Post
    T87a can run a 10 speed, that?s how we get around the t93 trans controller on the 10 speed tuning
    Will I have to change harnesses or anything?
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by LEAUXLFE View Post
    No, I’ve never done any harness swapping ti make this work on ZL1s, just swapped the computer and tune it
    14 Gen 5 Viper
    Aug 2022
    4
    Thanks a bunch... This is helpful. I was being told that the swap could not work. I was like, heck, the only difference is two gears... Same case and all. Just need the computer to make it work! That's all.
    Apr 2010
    11
    Did the transfer case from 8 speed work on the 10 speed?
    Tuner in Training chameleon's Avatar
    Aug 2014
    Long Island, NY
    41
    of course this thread like every other is left with no update. no this cannot be done this easy. the new T87A is expecting 1 wire signal from the E92A that matches it. only this completely complicates the entire thing. as the E92A uses the different fuel pressure sensor and all this cannot be done without changing a bunch of things to make it all match.
    there is a "conversion kit" being offered by "sean hamilton" on facebook which makes this much easier but i have no experience on how he is doing it, but he must have figured something out. if the single wire signal from the ecu can be replicated then it would be muuch easier to do. (fyi its a gear position signal) physically its all the same, transfer case is a bit different, but can be "modded"
    Sep 2017
    Stafford, VA 22556
    45
    Did this go anywhere? I'm curious about the changes needed to the 8-speed T87a to get it to work with the 10L80?
    Apr 2010
    11
    Yes, it now is possible to swap from a 6 or 8 speed to a 10 speed. I did it in my sierra. Get on Facebook and look for "Sean Hamilton". He makes the sub harness and has a list of parts youll need.
    Feb 2024
    USA
    2
    I need to get my 8L90? Or what ever it is in a 16 Denali Yukon tuned…
    However this post has me wanting a 10 speed automatic in the old 01 2500 suburban with the 8.1 L lol
