Results 1 to 3 of 3
Thread: 04 Lb7 balancing fuel
    Starting to tune my 04 lb7 with 135,000 miles and noticed the reported balancing rates seem problematic. Cylinder 7 shows + 9.5mm while coasting. injectors have 20k on them. What could be the issue? head gasket?
    please help
    04.5 Cummins CCLB
    04 LB7 Duramax
    01 Yukon
    72 C20 Project Truck
    LB7 injectors are known problematic but coasting is not typically the check point. +/- 4 in park, +/- 6 in gear at idle. This is not end all be all, but a guideline check for injector health. You should also google the the return check to see if the injectors are returning excess fuel.
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Jan 2014
    SoCal
    1,566
    That is a bad injector.
    Your only option is replacing the one or doing all 8 as a preventative measure, and cost savings on labor if another fails
