Is it common to tune to always run in open loop? I am working on such a tune. During tuning i found my best economy on the interstate is with an a/f ratio of about 16.5:1-17:1 and the chassis dyno has me at best HP at a lean sounding 13.5. So far It has resulted in about 7mpg when running on the interstate at 70 mph vs my attached tune. 2nd thought, This seems like too much of an improvement.
with the attached tune in closed loop my wideband seemingly cycles rapidly between about 14.5 and 14.9 while at steady state cruise with terrible fuel econ (10 mpg). I think the WB verifies the NB sensors and tune are accurate, or at least they are in agreeance.
current open loop tune is 17 mpg at an average of 16.8:1 at 70 mph.
engine: 6.0 LQ9, TBSS intake, 1 3/4 longs, 218/223 113 cam at 110 icl
1996 OBS chevy 4;10 gears 29.25 tire. about 2500 RPM at cruise.
2 new NB sensors and new WB
What is happening here? it seems like both my NB and WB are reading leaner than actual. There seems like no way could it be so bad when the wb shows right at 14.7, and no way it is that much better at around nearly 17:1.
