Results 1 to 14 of 14
Thread: Compare feature not working
    Jan 2015
    565
    Here is a funny issue. Whenever I try to open another 2020 eco mustang file to compare it to mine, the engine window goes blank. Tried multiple different tune files in several combonations. I can only read the trans or diagnostics or speedo. Has anyone else noticed this?
    Dec 2017
    767
    maybe by mistake you only have a tcm read file?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Have you considered posting the two files you are working with?
    Jan 2015
    565
    2020 Mustang Eco.hpt
    Open this file and the try to open it in the compare window(with or without any saved changes) I get a blank screen.
    Make changes and then tray to go to the saved changes window and open the base as the compare file and the same thing happens.
    Compare feature works fine if using the beta version of the software.
    Jan 2015
    565
    Any thoughts on this? Like I say, it works fine on the beta software but not the stable version.
    HP Tuners Support
    (foff667)
    28,265
    Quote Originally Posted by reubone View Post
    Works fine for me.
    Jan 2015
    565
    As I mentioned, the beta worked fine for me as well. It was the stable version that had the blank screen while using the compare feature with the 2020 Ecoboost file. I was looking for anyone else who had the issue with the stable version or if it was just me. Thank you for proving that the Beta version worked but you did not address the original question. Since the 5.0 release has also addressed the problem, this is now a dead issue. Have a nice day.
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Your probably using an older version than the compare file was read with
    EDIT I SEE YOU TOUCHED ON THE ISSUE, BUT MISSED WHAT HAPPENED
    THE COMPARE FILE WAS READ WITH BETA, YOU WERE USING THE STABLE, UNFORTUNATELY YOU CANNOT READ A FILE FROM A NEWER VERSION THAN THE ONE YOUR USING
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Jan 2015
    565
    That makes sense. I cant go back and verify whether or not that was the case but it could very well have been. Thanks
    HP Tuners Support
    (foff667)
    28,265
    Tested with 5.0 as well, works fine.
    Jan 2015
    565
    Already stated that but hey it bares repeating I guess. Try this one though. Open the tune file in both the regular and compare file sections, and try to look at the comparison log. Mine will not open even when comparing a modified version to the stock file. The compare log does not appear. Thanx for your time.
    HP Tuners Support
    (foff667)
    28,265
    I'm sorry you're having troubles and we'd love to help you. Have you already opened up a support ticket? If so, do you have your ticket number so that we can review the status? If not, please open a support ticket here: https://support.hptuners.com
    Jan 2015
    565
    Anyone else in the class run into this issue?
    HP Tuners Support
    (foff667)
    28,265
    Yes I was able to recreate it, did you open a support ticket as I suggested?
