15 Silverado faint spark issue
We have a 15 Silverado 5.3L here that another shop did an AFM Delete and an LLT2 cam with a phaser lockout.
Cylinders 1 and 3 show a VERY faint spark using a spark tester. Cylinders 5 and 7 are strong.
We have exchanged coil packs/wires between Cyllinders 5 and 1. The faint spark remains on #1
Where to look next?
Is that test with an inductive pencil type tester that lays over half the plug wire, or the plug out in open air? I had some plug wire heat wrap that was attracting spark from my plug wires before. Probably low chance, but figured I would mention.
Cylinder 1 had a flared out pin in the connector causing weak signal.
Cylinder 3 had a weak/bad ignition coil.
Fixed a pin, replaced a coil, and have spark on all 8
