hi guys can the scanner show the ignition patterns ?
Like an oscilloscope?
If so, no they can't.
thank you thats what i was looking for would you know if the mpvi2 has the scanner and edit feature already installed or do you have to buy it i see it advertised mpvi2 +vcm scanner+vcm edit make up vcm suite
You can download the software right on the website without even buying the MPVI but you need the MPVI to actually connect to the vehicle and use the editor and scanner on a vehicle. Without the MPVI you can only use it to sample the editor and see how the scanner functions with sample files.
ok thanks for your reply
