I need to up the rev limit some on a manual 2013 challenger RT. Can someone walk me thru it please. I have already adjusted the RPM limits in the engine section under Cutoff/DFCO and it did nothing.
you are looking to change park limits or what exactly are you trying to reach in engine speed
Remote Tuning [email protected]
the gas pedal and engine shut down about 5,800rpm and I need to go alittle higher
look at transmission limiter.
higher rpm at a stock rt are useless until you change the cam.
Have you done this before or you taking a wild guess?
I ve installed the 6.4 cam, this will give you more hp in higher rpm.
The 5.7 cam is lazy over 5k.
Dodge want a clear difference between the models.
Im asking about raising the rev limit using HP Tuners not cam specs and rpm on stock motors.
email me file
62 Biscayne 425/409 SS/D stock class car 10.60s
66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
Just easy,
raise your limits, even the runtime limit.
you need a tune for those mods of 6.4 cam swap
not just rpm
email me
Are you still running an MDS cam ?
Engine >fuel>Cut Off/DFCO> Park/Netrual and Drive , those tables are all stock, Need to change them to your desired RPM Limit.
Some Friendly advice,(if you still have) stock 5.7 cam @ 6500 RPMS , you are playing with fire , the 2010-2013 OEM springs open pressure is on the edge of the limit to control the valves above 6400/6500 rpms , and the valve to Piston clearence gets real tight on the exhaust side......I'm just saying been there done it and sometimes it's ok, and sometimes there are some bent valves to deal with.
