Thread: DeatschWerks 42lb/hr fuel injector help
    Sep 2022
    New to Hptuners working on a stock 2014 5.7 Hemi challenger the fuel injectors need to come out has anyone setup
    DeatschWerks SKU: 13U-00-0042-8 Matched set of 8 injectors 42lb/hr on a stock 5.7 , they are bigger injectors than
    stock and need to be tuned I have watched the RecklessMotorsportsUSA on injector pulse width tuning and the goatrope video however still a little confused was wondering if anyone that has set up the DeatschWerks 13u-00-0042-8 on a stock 5.7 could share their tune , I am just looking for something to get me up and running , and can dial it in from there.
    Yes I know I could just put in oem mopar injectors and for the most part be plug and play however , the cost on the oem stock injectors is considerably more, and that is $ that can go to other areas.
    Please excuse my noobish question , new to hptuners, not new to building cars sometimes my 52 year old brain needs all the help it can get when it comes to learning new areas , help truly appreciated
    Sep 2022
    disregard figured it out my self.
    hhhahaa I am running DW48's, if you contact there tech support, they will give you the detailed injector data.
    Aug 2021
    Yorktown VA
    196
    Be sure to log fuel flow rates, fuel masses, and injector pulse widths after entering your injector data and loading it up in a tune. I have found more often than not, that Deatschwerk's injector data tends to be quite a bit off from what they usually are putting out. Just FYI.
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
