I am retired ASE master tech. Transmission building was my Job. I am LS swapping a 2000 S10 2.2L to a 2004/2005 LM4. I upgraded the engine to an L33 5.3L, with Gen IV rods/pistons & 243 heads. I have dual fans, Holley front accessory drive an Elgin E-1839-P camshaft (.575/.575, 286/282, 220/224, 112) & I upgraded the 25lbs OE injectors to a GM 12580681 30lbs set for the cam. I also am using a Delphi AF10043 sensor.
I have not been able to purchase a module yet, HPtuners has the MPVI2+ on B/O & the MPVI3 is not yet available for sale!!! Anyone from HPtumers that may be able to share when the MPVI3 will be ready? I'm ready to buy!!!
I'll be starting with an updated tune file blindsquirrel did for me for the injector data I needed. Thank you again blindsquirrel.
1) add the idle file.
2) MAF tuning, I have a how to I got from some one on here.
All this is easy peasy for all you senior tuners, but is all new to me. I'm having a blast in my learning curve. If you have any tips or changes you believe i need to do feel free to advise. I'm all ears. I could borrow an tune module, but then I would have to borrow every time i need it. I do want to do more. I build performance transmissions for a speed shop and the more I understand what guy's are doing to trans tune the better!!!
