Error Code 81
Location Template Import Load.
Just built a fairly complex template with 6 dials using embed object to import the png file. Saved as a template but when tried to open then no joy. Any help would be appreciated.
Many thanks
This happened to me once or twice as well. Hopefully you still have the project saved that you used to create the template. I'd recommend trying to re-save the template and seeing if that helps at all. I think I just named the template differently the second time. I'm not quite sure why it sometimes fails to save the template correctly.
