Results 1 to 10 of 10
Thread: SIMOS 18.1 Tuning any tipps?
    Dec 2021
    Manchester TN
    41
    Hey,
    i put on a 1.8t a IS38 and trying to get some power but i feel like i don't get any power change or boost change.
    Thanks so much for the Help
    Matthew Wagon Stage 3 base3.hpt4th log.hpl
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    207
    You need to increase the commanded boost
    Xstages Motorsport
    Tuning inquiries:
    ECU, TCU, CPC Online Tuning
    Whatsapp: +971503383340
    Email: [email protected]
    Insta: @xstages.motorsport
    www.xstages.com
    Dec 2021
    Manchester TN
    41
    Quote Originally Posted by outlaw_50 View Post
    Do you mean the Max PR? i did increase that but seem not to change a lot.
    Thanks For the response
    Dec 2021
    Manchester TN
    41
    i forgot here is the Base file and current file together
    Sep 2014
    17
    you need to learn the ecu before trying to tune these..
    you didnt raise max intake air, you did nothing to TTA/ATT tables, aircharge to tq is not good.
    max PR is pretty low.... put it at least 3.5-4
    you will also need to adjust cam angles to get top end out of it.
    Sep 2010
    Houston
    131
    Turbo Upgrades on these ecus require extensive Turbo Model work for correct functionality, there a few documents you can read on how raising boost, remember is a complex torque model system yet very simple if proper data is applied, I attached a simple document you can read and will guide you thru the process of increasing torque and a few limiters you need to address, NOTE: You can get away if you have access to the is38 turbo flow model it would make life easier , pm me and I can send you the data if you don't have a Golf R ecu read
    cheers
    Dec 2021
    Manchester TN
    41
    Quote Originally Posted by smelly240 View Post
    Thanks so much for the Input i will research more, i try to learn and tune, i will look at the cam angles do you have any suggestion on that?
    Thanks again
    Dec 2021
    Manchester TN
    41
    Quote Originally Posted by GCtech View Post
    cheers
    Thanks so much i start reading
    Mar 2024
    7
    IS38 turbo on 1.8L engine
    Hi can you help me to tune my ECU for the IS38 setup ?
    Nov 2017
    venezuela
    3
    hi
    Hi friend, where can I get a course on European cars?
