So its a 2016 camaro SS, it has a tsp cam with the 32% fuel lobe, drop in forged pistons with stock compression, LT4 injectors and HPFP an the stock in tank pump.
The car is down on power, it only made 476whp on e85, thats only 10whp more than the stock cam numbers, so i took the car on the road and did a pull, the car went on REP, the code was for the fuel pressure sensor being too high, and on the datalog rail pressure gets pinned at 3700psi, so im guessing im way over what the injectors can manage and that keeps them shut.
I copied the injector data from a z06 and the pump, maybe i overlooked something on the tune?
Is commanding lower low side pressure the only way to manage the pressure on the high side?
misscircum2.hpl
lt4 inj dyno4 e85.hpt
