Results 1 to 8 of 8
Thread: Gti mk6 ecm cant be detected
    Sep 2022
    12
    Hi, anyone have the same issue im facing? I cant read my ecm only TCM is showing. Thank you for your suppport
    Sep 2014
    17
    There are different mk6 ecus - some with diff tuner protections - ive even done some that are only bench. Contact support - they can help better than a forum post.
    Sep 2022
    12
    Hi, thank you for your reply. I have tried 3 different cars already and have no luck detecting the ecm.. all i can detect is the TCM, even on VCM scanner no data is showing. I tried reading it thru Auto tuner and the ecu is MED 17.5 which should be supported as per website.. i hope you giys could shed some light on this..
    I also tried contacting support and pete is helpful but cant seem to figure it out aswell.
    May 2014
    USA
    446
    Have a screenshot of the error it shows when you go to read the ECU in VCM Editor?
    Sep 2022
    12
    Hi, technically when i read the ecu it only shoes tcm and cant even detect the ecm.
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    maybe its obd wiring related issue
    Xstages Motorsport
    Tuning inquiries:
    ECU, TCU, CPC Online Tuning
    Whatsapp: +971503383340
    Email: [email protected]
    Insta: @xstages.motorsport
    www.xstages.com
    I'd say have a look in the drop down after confirming what OS your ECU is running. That way when you are in the read screen on the editor you can select your ecu (There is going to be a lot of selections)
    2013 Audi A8L 3.0T WIP
    Sep 2022
    12
    I manage to read mine, but i had to flash it on thr original file using auto tuner
