i need a little help in the right direction. basically im rebuilding an auction car that had aswapped 5.3 in it. I rebuilt a gen iv 6.0 with basically a com cams stge 3 with a holley short efi intake, 102mm throttle body. this setup is only running a map sensor. I have installed an AEM widband. the issue im having is i can get the VE table to make it idle decent. When i start giving it accelerator it leans out and dies. It has Stock LS3 injectors.68gtowith408strokerinfoloaded1.hpt68gtoidleto2000leanout.hpl. Im sure i dont have my math right in the logging. Still working on that. I have the serial connector from the blue wire coming into the hpt.
