2010 CTS-V 6sp Automatic.
Headers, no cats, 2.55 pulley, Airaid intake, FIC1200cc injetors, dsx flex fuel, cooling mods, and I just added Deatchwerks DW300 dual drop in replacement fuel pumps.
Initially my (stock pump) FSCM tune, the High Flow Mode commanded is 70 psi, normal is 50psi. This caused the new fuel pumps to instantly shoot to 100% duty cycle and overshoot the targeted FP to 99psi and throws code p069e. I've editted the FPCM tune, by reducing the High Flow Mode FP to 60psi (plenty of injector for this). As you can see in the logs, my commanded FP and actual FP are dead even at 60psi, until suddenly for some odd reason unknown to me, the fuel pump DC jumps to 100% and my FP shoots to 89psi.
From there I've lowered the Fuel Pump Openloop Duty Cycle tab so that the highest value is 80%. I flashed the tune and it made no difference at all. Goes straight to 100% whenever it wants to. After speaking with Justin White, he tells me this is common and he has tested it on all 12 CTS-V operating systems and there is nothing we can do about it.
So my question to HPTuners, you advertise that you've unlocked the FSCM, but do we really have control? Is there something else controlling the FP duty cycle that we dont have access to on this platform?
Damn, sorry I don't have my latest tune file. I will upload when I get to my other laptop. I've also added Instantaneous Fuel Flow to my scanner for future use.
DW300 WOT spike.hpl
Check out the FP riding perfectly and then it just shoots to the moon...
Edit: Here's the tune. Remember, my injectors are scaled by 50%. CTSV with FPCM DW300 pumps 60psi cranking.hpt
