Results 1 to 4 of 4
Thread: Resetting TPS or accelerator pedal position sensor
    Is there a way to reset the TPS or accelerator pedal position sensor on a 2014 GT500? With my 91 and cable driven throttle body with the megasquirt it has setting to have the computer relearn 0 to 100 on the TPS. But I am wondering if there is any like that for an electronic throttle body or electronic pedal sensor.
    Potential Tuner USMC363's Avatar
    Oct 2023
    Nashville, TN
    2
    Bump..
    Oct 2016
    Poland
    1,750
    Quote Originally Posted by mlecy View Post
    Simple answer is no. You should never have to re-learn TPS in any modern Ford. If something is wrong with TB its either mechanical or something messed up in your tune
    Oct 2023
    Nashville, TN
    2
    Thanks Veefour. Yeah definitely something in my tune. Car won't shift before it hits the limiter at WOT. Every gear. I have an RTD device that came with the car. I'll be ordering the MPVI3 next month so I can dig down in the editor. Tuner at Lund said it was set to shift at 7k, with limiter at 7300. I hit 7300 and car shuts off.
