Help what to adjust hp tuners
As in it has already been tuned and runs fine otherwise, or as in the cam was literally just changed and has not been tuned at all yet?
Remote tunes
Pops at low rpm. When I let off and hit it it pops sometimes
Any idea what I can adjust
Is the throttle body closing causing the "popping" noise?
2013 OBM A6 CTS-V Coupe
Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
2006 Black Raven STS-V (Traded In)
Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
Ok, sorry to hear that. There are only two things in a tune that can cause intake popping, or exhaust popping, or backfiring, etc; Fuel mixture that the engine doesn't like, or Ignition timing that the engine doesn't like. Usually I have seen intake popping or backfiring when the fuel mixture is too lean or spark plugs too hot, but the best way to pin it down is going to be to get a datalog of the issue occurring with all the relevant parameters for airflow, fuel, and timing. The corresponding tune file would also be helpful. If nothing in the tune stands out, the next place to look (actually sometimes the best First place to look if you trust the tune) is on the mechanical side.
Youll want to confirm your fuel pressure is not dropping when that happens, especially check for any vacuum leaks, and none of those or the tune stand out, intake valve actuation/sealing would be the next place to look - maybe compression check all cylinders as a first step. A fuel injector or two leaking, dribbling fuel or not spraying enough volume or correct pattern could also be a culprit.
Overall start with the easiest to check first (post datalog here) and hopefully it isnt too involved.
