Results 1 to 8 of 8
Thread: Chasing Knock and boost bypass - 3.0T
    Tuner in Training Only6NoTricks's Avatar
    Sep 2022
    11
    Lately I've been chasing down some knock on my 13' 3.0T A8L, also figuring out if I can optimize power anywhere else. I'd believe my trans tune is performing well, shifting around 7100-7200 in sport. There isn't any E85 stations near me so a E85 blend isn't possible unfortunately. Fueling seems spot on, right around .82λ. Any tips or tricks? Thanks in advance!
    BASE TRANS V1.1.hpt
    BASE FILE V1.2 .hpt
    A8 V2 45min.hpl
    2006 Saab 9-3 SC GTX3582R & GTX2867R Compound setup - 525whp 509ft-lb!
    2013 Audi A8L 3.0T WIP
    Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    141
    There are number of reasons why its having that amount of knock.
    - Check Spark Plugs
    - Check Injectors
    - Any vibration would set the knock sensors (bad engine mounts, Trans mounts, leaking or vibrating exhaust manifold)
    Xstages Tuning and Performance
    Tuning inquiries:
    Whatsapp: +971503383340
    Email: xstages.motorsport@gmail.com
    Insta: @xstages || @outlaw_50
    Sep 2022
    11
    Quote Originally Posted by outlaw_50 View Post
    - Check Spark Plugs
    - Check Injectors
    Definitely do need trans mounts at some time in the future, the car has 122k on it, on I believe what are still the original trans mounts and engine mounts. I?ll look into a colder range spark plug. Is there any you recommend?
    Quote Originally Posted by Only6NoTricks View Post
    BASE TRANS V1.1.hpt
    BASE FILE V1.2 .hpt
    A8 V2 45min.hpl
    you need to adjust your spark tables better. your getting knock because your hitting 20*+ timing on 93 octane fuel. you need to back it down some. or get some more octane in the fuel tank. or get meth injection.
    Sep 2022
    11
    Quote Originally Posted by Hemithis01 View Post
    Just to be clear this will be the MBT Spark tables (ECM-29500) Right? To be honest I'm having trouble understanding the mg for airflow. I'm aware its mass airflow, but wouldn't the engine be ingesting a lot more than 1200mg of air? lol.
    My apologies if any of my questions are dumb, I'm learning more and more haha.
    yes that is the mbt table but you will never get close to that on 93 octane. i looked at your file real quick and noticed your rich base tables are 0 out all but last few rows. those are tables i use to control timing. i would go back to factory tables and make small adjustments on those tables until to find the limit of your set up.
    Sep 2022
    11
    Ahhh I see now. I thought those were the tables the ECU only used in an overly rich event (Leaky injectoro o-ring etc) Thank you!
    Sep 2022
    11
    Thumbs up
    Great success! 0 knock whatsoever. It's time to start adding more to the tables. Weirdly enough however, the car in sport after the revised tune decided it wanted to start shifting at 6500 or less. Before I was doing just about 7200-7300rpm before it shifted
    I generally understand Torque to aircharge, however for the life of me I cant figure out how to stop the car from opening the bypass valve during a pull.
    BASE FILE V1.5 .hpt
    22-10-02 18-04-26.hpl
    EDIT: I looked over the logs again and I don't think my foot was completely to the floor. Damn flip flops.
